Configuring ATA 186 to work with 02 Lines
Hi Guys,
I need configure the ATA to work with 02 fax equipments. I know that is possible to do, but, I have doubt: The line 0 and line 1 will work with G.711 or Line 0 will work G.711 and Line 1 will work G.729. I remember that it's necessary change the MAC address or included zero the start and retired number in the finish, It's right?
Wilson
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: Configuring ATA 186 to work with 02 Lines
No, only one port at time optionally supports g.729 that you would not use anyway for fax.
Please remember to rate useful posts with the scrollbox below!
Hall of Fame Super Red
Hi Wilson,
The second port of an ATA only supports g.711 This is what usually throws a wrench into the thought process here;
Have a look at these two good posts that relate to this type of issue;
From Paul @ Cisco;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified Communications and Video&topic=General&CommCmd=MB?cmd=pass_through&location=outline@^1@@.1ddc9467/3#selected_message
From Jan;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified Communications and Video&topic=IP Telephony&CommCmd=MB?cmd=pass_through&location=outline@^1@@.1ddf3e5c/4#selected_message
Hope this helps!
Rob
Yes. You need to change mac address for the 2nd line.
If you have a choice, use an FXS port in the router for fax. ATA are often source of trouble with fax.
Hi Bevilacqua,
In relashionship a Codec, is correct the affirmation Line 0 work with G.711 or G.729 and Line 1 work only G.729?
Wilson
Bevilacqua,
Could you indicate the link or documentation about how configure ATA to work Line 0 and Line and the use codec?
Wilson
Hi Wilson,
From Paul @ Cisco;
From Jan;
Hope this helps!
Rob
153
