10-07-2013 05:03 AM - last edited on 03-25-2019 08:25 PM by ciscomoderator
I need to add and configure an ATA 187, but I can not find the configuration option for this device.
Can I add this option to the Cisco Call Manager?
10-07-2013 05:10 AM
Hi Nicolas,
What is CUCM version u are using?
ATA 187 is supported on CUCM Versions 7.1.5, 8.0.2, or higher.
Can u share the error snapshot of CUCM?
regds,
aman
10-07-2013 06:17 AM
Thanks for your help.
The version is 7.1.5
10-07-2013 06:22 AM
You'll need to download and install the latest device pack for 7.1.5
GTG
Please rate all helpful posts.
10-07-2013 07:56 PM
Hi Nicolas,
You can download the latest version 9.2(3). Before u do that , u need to install QED [Quick Enabler Device ].
The same can also be downloaded from below link.
regds,
aman
