Configuring CAC on a Call Manager Express
Is it possible to configure CAC on a Call Manager Express 7.
Is there a link to configure this.
Best regards
Hall of Fame Super Gold
Re: Configuring CAC on a Call Manager Express
Not that I'm aware. If you use a GK however, all the regular CAC features should be applicable.
CME can do a limited amount of CAC itself without a gatekeeper, either by limiting the number of simultaneous calls associated with each dial peer or by using RSVP.
But, per dial peer call counting doesn't work well if you're using more than one dial peer per WAN link, and RSVP requires end to end support within your network.
Hope it helps!
Best regards,
- Adrián.
With CUCME 8.5 is it possible to have CAC ?
I've read SRND but no reference to that is made...
Thanks for helping,
Dino
362
