08-17-2013 01:11 AM - edited 03-16-2019 06:54 PM
Hi there,
Can "call forward unregistered" some how be configured on a CME 7.1 for SCCP phones, or is ther some workaround?
I know, for SIP it's possible. What I'm trying to achieve is, if a home ofice SCCP phone/DN is not registerd with the HQ, the incoming calls should be routed
to the mobile nr.
Norbert
Solved! Go to Solution.
08-17-2013 10:30 AM
You also need to upgrade the CME to 8.6 . The behavoir has changed over the years . The unregistered condition is now recognised as busy . Read the doc below....
“In earlier versions of Cisco Unified CME, a busy tone was played for callers when the
callers are unable to reach the SCCP phone number. In Cisco Unified CME 8.6 and later
versions, a fast busy tone is played instead of a busy tone for callers who are unable to
reach the phone.”
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrans.htm
l#wp1161650
So "call forward busy" should work.
Hope this helps!
Karthik Sivaram
08-17-2013 09:59 AM
Have you checked with call forward busy?
ephone-dn x
call-forward busy
Karthik Sivaram
08-17-2013 10:30 AM
reach the phone.”
l#wp1161650
Hope this helps!
Karthik Sivaram
