configuring cisco 7906G
helo,
one of my friend have a network at home using ethernet over power line adaptors and Netgear ethernet switches. they are trying to set up two Cisco 7906G IP phones on the network, To date they not been able to get the phones to work. can you advise what can be missing ,additional software or whether they are just not programming the phones properly.
Re: configuring cisco 7906G
Hi Munna,
You'll need at first the call agent which will provide the conf file,FW to your Phones and process any needed calls between them
Do you have any thing that will act this function ??
Thanks for the reply, not sure if they have a call agent. is that something which can be downloaded and used. what agents are available
Munaf
108
