Configuring DN to forward to outside number
I have a user that will not have an IP Phone but needs a DN on the CallManager, I need to configure the DN to forward all calls to his cell phone number. I can make this work when I have the extension associated with a device but as soon as I disassociate the DN from the device you hear "Your call cannot be completed..." from CUCM. I have check to make sure that the Active Checkbox is marked under the DN configuration. We are running CUCM
8.6.2.20000-2
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Configuring DN to forward to outside number
In addition to great suggestions here, +5 for Java and Rob, you should be able to use the unassociated DN as well, just make sure you have proper CSS assigned to it.
HTH,
Chris
Rob, accidentally rated you with +4, any idea how to adjust it, sorry buddy :-(
Configure a translation pattern to do such thing.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hall of Fame Super Red
Hi Jeff,
I've done this before using CTI-RP's (CTI Route Points) and it worked swell
Cheers!
Rob
EDIT: Holy crap Java! You must be jacked up on the Coffee today >>>hahahaha! +5
HTH,
Chris
Hey Chris,
No worries my friend
It probably wasn't worth a 5 anyway I liked your idea better (+5)
Cheers!
Huff
Looks like you cannot change it, you get +5 extra for my clumsiness
https://supportforums.cisco.com/docs/DOC-8052
Jeff, my apologies for stealing your thread here this way, hopefully you got your options.
Chris
232
