Configuring Encryption on CUCM 8.6 and Unity 8.6
Hi voice team, i´d like to know what i need (hardware) to configuring voice encryption on my CUCM 8.6 and Unity Connection 8.6 too.
I have two MCS 7816 (CUCM) and MCS 7825 (Unity).
Thiago
Everyone's tags (1)
1 ACCEPTED SOLUTION
You need, at least, two
You need, at least, two tokens for the whole cluster.
That's clearly explained in the document:
Obtain at least two security tokens and the passwords, hostnames/IP addresses, and port numbers for the servers that you will configure for the Cisco CTL Client.
Not sure how you came up with the understanding of token per phone????
java
if this helps, please rate
www.cisco.com/go/pdi
http://www.cisco.com/c/en/us
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/8_6_1/secugd/sec-861-cm.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/security/guide/8xcucsecx.html
java
Ok, but i dont understand, i
Ok, but i dont understand, i will need a USB Token to encrypt the phones?
If "yes" i need a usb token for every phone?
java
OK, sorry for the
OK, sorry for the misunderstanding.
85
