Configuring external calls in CUCM 8.6
Hello to all ,
I have a CUCM 8.6.2.20000-2 and I need to configure the external calls . In the past we has configured the calls and gateways in MGCP , but today we need to configure in H.323 :
GATEWAY CONFIGURATION ( MGCP Configured )
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
h225 timeout tcp establish 2
voice class custom-cptone 1
dualtone disconnect
  frequency 450
  cadence 300 200
ccm-manager fallback-mgcp
ccm-manager mgcp
mgcp
mgcp call-agent X.X.X.X 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp profile default
Thanks for the help !
Hugo
Everyone's tags (2)
There are plenty of docs on CCO on CUCM with H323 configuration, have you searched for any of those and tried to follow the instructions???
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hello javalenc ,
Thanks for your time , I am looking for an expert user who can give me some advice in this problem .
I still trying to resolve this
And what problem is exactly you're facing??? your post only mentions you want to configure calls using H323 and for that the links on CCO will suffice
java
java
Re: Configuring external calls in CUCM 8.6
Thanks Leonardo and Jaime :
I am reading the documentation now . My problem is with the outbound calls , I guess is about dial-peer voice configuration in h323 .
Thanks in advance
Hugo
You need the dial-peers pointing to the PSTN, and you need to send the digits on the format accepted by the Telco.
If you are using an E1/T1 you use a pots dial-peer or if you re using a SIP Trunk you use a voip dial-peer pointing to the SIP Proxy.
Take a look on this doc:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_confg.html
Rate this if helps you
Leonardo
542
