Community Member
Configuring Forced Authorization Codes on Communications Manager Express
Hi All,
I am attempting to configure Forced authorization Code Feature on CME, Would appreciate if any one can share your view point on how to go about configuring this feature on CME. My intention of configuring this is to Prompt the user for a Code when dialling out to specific Numbers (Long Distance and International).
sandeep
1 REPLY
Re: Configuring Forced Authorization Codes on Communications Man
please always search NetPro, this has been asked several times before
IP Telephony: Can CME do feature access codes? What about CDR?
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc250bc/0#selected_message
IP Telephony: CME class of restriction.
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc25284
Unified Communications Applications: CME and FAC
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc17d46
and there are a lot more if you look for fac + cme
java
if this helps, please rate
java
www.cisco.com/go/pdi
306
