03-23-2008 12:57 PM - edited 03-15-2019 09:35 AM
How to configure the fxs port which will be used for connection to the fax machine? And how to configure a dial peer fot that?
03-23-2008 03:18 PM
dial-peer voice 100 pots
destination-pattern XXX
port X/Y
that's it.
03-23-2008 04:17 PM
Ok so how is the configuration for fxs port?
03-23-2008 06:04 PM
Defaults are fine.
03-24-2008 08:14 AM
Now fax machine can receive from outside but cannot send fax to outside. what can be the problem ?
03-24-2008 08:16 AM
do you have a dial-peer pointing to PSTN
dial-peer voice xx pots
destination-pattern 9T
port x/y
