Configuring FXS port and connecting a fax?
blackswans
How to configure the fxs port which will be used for connection to the fax machine? And how to configure a dial peer fot that?
5 Replies 5
paolo bevilacqua
dial-peer voice 100 pots
destination-pattern XXX
port X/Y
that's it.
Ok so how is the configuration for fxs port?
Defaults are fine.
Now fax machine can receive from outside but cannot send fax to outside. what can be the problem ?
do you have a dial-peer pointing to PSTN
dial-peer voice xx pots
destination-pattern 9T
port x/y
