Configuring IOS DHCP server with Option 150 for CUCM
Hi all,
Could someone share a link or a document on how to configure DHCP server in IOS with option 150 for CUCM ? I am trying to configure DHCP on a 3750 switch for a test environment. Thanks in advance !!!
D.
2 ACCEPTED SOLUTIONS
Re: Configuring IOS DHCP server with Option 150 for CUCM
You can easily find info if you search CCO
Configuring DHCP Features and IP Source Guard
I searched DHCP configuration and on the left side there was the option:
"Cisco Catalyst 3750 Series Switches" to further filter the search.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Bronze
Hi friend, this configuration is working fine fo me:
interface Vlan1
ip address 192.168.11.1 255.255.255.0
ip dhcp excluded-address 192.168.11.1 192.168.11.20
ip dhcp pool 40
   network 192.168.11.0 255.255.255.0
   option 150 ip 192.168.11.206
   dns-server 192.168.11.4 192.168.1.4
   default-router 192.168.11.1
hth
David
java
java
Bronze
interface Vlan1
ip dhcp pool 40
hth
David
Thanks Java !! Thanks David !!! I appreciate your response !!!
D.
13515
