Configuring multiple MSN Numbers on BRI Interface
Hi everyone,
I've got an ISDN line with around 8 MSN numbers connecting to my BRI 0/0/0 interface.
I'm trying to configure the interface to answer only specific MSN numbers, but can only find the option to answer up to 2 numbers using isdn answer1 <number1> & isdn answer2 (number2).
Any idea how this can be done?
Any help is much appreciated.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Configuring multiple MSN Numbers on BRI Interface
voice translation-rule 10
rule 1 reject /5551234/
voice translation-profile fxo-in
translate called 10
voice-port x/y
translation-profile incoming fxo-in
You can use a voice translation-profile with rule to reject calls to the number you do not want to answer, under the voice-port or incoming DP.
hope this helps, please rate post if it does!
bevilacqua,
Thanks for your reply.
Can you please offer an example config that I can use to try it out ?
Thank you.
translate called 10
voice-port x/y
Paolo,
I've tried the suggested configuration but unfortunately the call still rings on the secretary's phone.
Here's what I've added:
voice translation-rule 2
rule 1 reject /23105551234/
voice translation-profile dropmsn
translate calling 2
translate called 2
voice-port 0/0/1
translation-profile incoming dropmsn
compand-type a-law
cptone GR
connection plar 49
bearer-cap Speech
I've also performed a test voice translation and it verifies that the call is blocked on rule 1.
Any ideas ?
Do not use connection plar.
Instead, assign the number you want to answer as secodary for the ephone. And, check with "debug isdn q931" and "term mon" that the called number is exactly the same you want to reject.
Paolo,
I'm left a bit puzzled by your last response.
ext.49 refers to a pilot hunt list:
ephone-hunt 1 sequential
pilot 49
list 30, 50
timeout 10, 10
description Huntgroup-Sec->Everyone
Can you please provide an example of your suggestion to help make it a bit clearer for me ?
pilot 49 secondary 23105551234
or simply
pilot 23105551234
Paolo,
I'm still having problems blocking the msn number I want. Here's the complete relevant configuration, perhaps you can point me as to where I've incorrectly configured the system:
translate calling 2
translate called 2
voice-port 0/0/1
compand-type a-law
cptone GR
bearer-cap Speech
list 30, 50
timeout 10, 10
Do I also need a dial-peer for the above to work as I didn't use any previously due to the 'connection plar 49' command.
Many thanks,
Well, the "reject" number and the pilot secondary should be different, it is so in your actual configuration ? Also you don't need "translate calling".
You also need a DP with "incoming called number ." and "direct-inward-dial".
Paolo,
Thanks again for your input.
Can you verify the following configuration is correct as per instructions so I can give it a try? :
translate called 2
voice-port 0/0/1
compand-type a-law
cptone GR
bearer-cap Speech
pilot 49 secondary 23105554321
list 30, 50
timeout 10, 10
dial-peer voice 100 pots
destination-pattern 23105554321
direct-inward-dial
port 0/0/1
Thank you.
Seems fine ...
Note in reality cptone for BRi prots doesn't do anything, and beare-cap is often best left to default.
Thanks Paolo,
I'll give it a try and let you know.
Paolo,
Your suggested configuration worked fine ! Many thanks for your patience and effort!
What I'd like to try out now is apply the above scenario to a voice gateway which routes all incoming calls to a CUCM system.
Here's what I've tried, but it didn't work on the remote system:
rule 1 reject /210500500/
translate called 2
voice-port 0/0/0
dial-peer voice 400 voip
destination-pattern 210...
voice-class codec 1
session target ipv4:10.0.0.1
I tried also applying the translation-profile to the dp 400, but it didn't work.
In my previous example, we placed the number we wanted to ring, as a secondary on the hunt group's pilot (ephone-hunt 1 sequential
pilot 49 secondary 23105554321).
In this particular case, all incoming calls are routed to the call manager system.
Any ideas or suggestions ?
Just configure a proper destination-pattern for the numbers you want, under DP 400.
Thanks for the nice rating and good luck!
Paolo,
Correct me if I am wrong, but I can only define one destination-pattern under each dial-peer, or use a pattern that matches all incoming numbers e.g destination-pattern 210....... (
In this new case, I've defined a generic pattern that catches all possible patterns I need (210500501, 210500502 e.t.c).
I don't understand what additions I must make to get the new scenario working;
An example based on the configuration below would be much appreciated:
translate called 2
voice-port 0/0/0
voice-class codec 1
Seems fine, all numbers beginning with 210 and six more digits are sent to 10.0.0.1
However, for some reason, 210500500 is not being rejected.
I also tried adding the translation-profile to the dial-peer you saw, but the system still answers 210500500!
Any further ideas ?
Check ouput of "debug isdn q931" with "term mon". Worst case you can route the number to a fake IP and it won't answer.
188
