Community Member
Configuring OPERATOR TELEPHONE in CME
I have CME with 4 fxo lines
I define an operator telephone with single button
I forward call to fxo lines from outside with connection-plar
voice-port 0/0/0
connection plar opx 0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/2
ephone-dn 100 dual-line
number 0
label 0
description OPERATOR
name OPERATOR
ephone 1
mac-address 001B.D491.5825
username "OPERATOR" password 100
type 7931
button 1:100
I want maximum two-calls are answered than transferred by the OPERATOR.
This is O.K.
Problem is that;
two calls comes
first-one, is in hold state
Operator makes Confrence with the second-one and inside telephone.
first-one joins automatically, which is unwanted.
I need to use only one-button
PLEASE HELP
1 REPLY
Bronze
Re: Configuring OPERATOR TELEPHONE in CME
Your config is dual-line,
\ephone-dn 100 dual-line
number 0
label 0
name OPERATOR
It should work as above or try with single line config, ephone-dn 100.
225
