Community Member
Configuring SIP IP Phones
I need to configue 79XX IP phones with Asterisk as SIP clientes. I do not know if I should add the SIP firmware to the phones or it is already added.
the phones was connected to CCM and registerd as SCCP, I do not know if the phone connected to the CCM and the phone did the first time upgrade. In this case does the phone download two Firmwares  (SCCP and SIP) or just one.
Re: Configuring SIP IP Phones
The phones can only have one FW, if the last one used was SCCP then you have SCCP phones
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Thank you too much for your reply.
If I need to use the IP phone using SIP, but I do not have CCM or CCME for upgrade or to change the FW. Is there any solution for this?
203
