Configuring Track RTR in cisco 3925 router.
I need configure Track rtr in cisco router 3925
previously had a 7200 which supports the RTR is now migrated to a 3900
my question is whether the 3900 supports RTR feature or
well if the following command is the evolution (track 1 ip sla 1 reachability) rtr and if functionality is the same??
IOS 3900: c3900-universalk9-mz.SPA.154-3.M.bin
IOS 7200: c7200p-spservicesk9-mz.124-15.T13.bin
1 ACCEPTED SOLUTION
HelloYes , it supports.track
Hello
Yes , it supports.RTR defunation updated to IP SLA :-)
 ! monitors ip sla 1 and removes the track 1 route if unreachable
Kindly check the below link which is veru useful :
www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html#wp9000801
http://cradlepoint.com/sites/default/files/productdocs/Cisco_WAN_Failover_Configuration_via_IP_SLA.pdf
Note: this forum for IP telephony , it will be better if you go for the forum of LAN,switching and routing "network infrastructure" . Go for the below
https://supportforums.cisco.com/community/6016/lan-switching-and-routing
please rate all useful information
1 REPLY
Hello
172
