Community Member
Configuring VWIC-1MFT-E1 on 2621XM router
I have a VWIC-1MFT-E1 in wic slot 1 of a 2621xm router running cisco IOS 12.4(17).
However I cannot confiure my pri-group under controller e1 command.
I cannot also do a show isdn status command.
Is there something I need to turn on?
Please assist.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Configuring VWIC-1MFT-E1 on 2621XM router
You need DSP to configure card as PRI, and you don't have that.
You would need AIM-VOICE-30 that is a card that goes inside the router, or an NM-HD-xxx to host the VWIC. The first alternative is probably cheaper. The second one, when acquiring a network module supporting the latest generation DSP called PVDM2, would give you more feature and a longer technological lifespan.
You will probably find that you have not specified the card type.
Configure the card as follows, specifying the appropriate slot and wic of course:-
card type e1 1 1 (Slot/WIC)
Allan.
Community Member
I cannot seem to configure the card type. Under config it does not allow me to do that.
In sh run it shows controller e1 0/0
Typically if the card-type is configured you will see the controller E1 in the configuration. If it was not configured, then there would be no controller.
Is there already a PRI group configured under the controller? Shutdown the controller remove the pri-group and reconfigure.
Pls post the config, and show diag to sanity check.
Allan.
Community Member
Here is the sh run and sh diag
------------------ show running-config ------------------
Building configuration...
Current configuration : 1478 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname NSC_CITY_VG
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
isdn switch-type primary-net5
!controller E1 0/0
interface FastEthernet0/0
ip address 192.168.24.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.24.1
ip http server
no ip http secure-server
control-plane
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.2.11
ccm-manager config
mgcp
mgcp call-agent 192.168.2.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip redundancy
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package dtmf-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
line con 0
line aux 0
line vty 0 4
password
login
end
NSC_CITY_VG#sh diag
Slot 0:
C2621XM 2FE Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time 02:13:10 ago
EEPROM contents at hardware discovery:
Hardware Revision : 4.0
PCB Serial Number : FFFF
Version Identifier :
Product (FRU) Number :
Chassis Serial Number : JHY0738K11M
Part Number : 73-7754-06
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : C0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 6D 41 04 00 C1 0B FF FF FF 46 46 46
0x10: 46 FF FF FF FF 89 FF FF FF FF CB 12 FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF C2 0B
0x30: 4A 48 59 30 37 33 38 4B 31 31 4D 82 49 1E 4A 06
0x40: 04 00 81 00 00 00 00 42 43 30 80 00 00 00 00 FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
E1 (1 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision F0
Serial number 33070310 Part number 800-04475-03
FRU Part Number VWIC-1MFT-E1=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 21 01 00 01 F8 9C E6 50 11 7B 03 00 00 00 00
0x30: 78 00 00 00 04 12 13 00 FF FF FF FF FF FF FF FF
NSC_CITY_VG#
Firstly your configuration indicates that you are configuring your E1 through MGCP, therefore have you configured the gateway endpoint accordingly within CallManager, and also in the correct slot?
Looking at the 'show diag' I would expect to see controller 0/1 Slot 0 WIC 1.
How have you configured the gateway with hostname or IP address. I have noticed that have not configured a domain-name on the gateway, therefore ensure that if you use hostname for the gateway that you only use NSC_CITY_VG, and the CCM and resolve this.
If you have configured the endpoint correctly then I would expect CallManager to configured the pri-group. However are you attempting to reconfigure the pri-group as you have a fractional E1?
If this is not the case then try the following to download the config from CCM:-
1. remove all ccm-manager related commands.
2. configure 'network-clock-particpate wic 0'
3. reconfigure ccm-manager commands.
Allan.
Nice spot pbevilacqua, completely overlooked that aspect on the 'show diag'
Allan.
Community Member
Thanks, I found out that My router did not have an AIM module on it. I assumed this would normally ship with it.
Community Member
I was wondering if there is a slot on the router where the AIM-Voice-30 card goes into?
Take a look at the following link, it describes the various AIM cards supported, including the AIM-Voice-30.
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_data_sheet09186a0080088753.html
You see that it is a daughter card installed internally on the hardware platform.
Allan.
Hi Allan,
there is no "card type" command for VWIC-xMFT-xx hardware, that is natively T1 or E1 depending on the version purchased.
The command is available for VWIC-xMFT-xx cards that are "universal".
Fat fingers, I meant
The command is available for VWIC2-xMFT-xx cards that are "universal".
Thanks for the nice rating and good luck!
958
