Confused on Cube
I wanted to know can someone point me in the right direction on Cisco cube as far as any type fo diagrams or documention.
The company I work has a company that they bought and they have IP overlap and they were told that they should invest in
the Cisco cube.Exactly were would I place such a router in the network because I don't know and and is there anything special
that needs to be done on our end for the Lync users. The other company is using Lync for Voice and they want that company to
be able to use the lync client for IM and talk to our Cisco client. and to make calls as if they were in the office here.Thanks in advance for anyhelp and have a great day.
1 ACCEPTED SOLUTION
Green
Confused on Cube
Here is a link to the interoperability portal example of CUCM 8.5 to MS-LYNC via CUBE
It shows diagrams and config info.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns833/1046507_new.pdf
The portal index link is
http://www.cisco.com/en/US/netsol/ns728/networking_solutions_program_category_home.html
You can look through the tested solution and find solutions which are near to your requirements
Alex
Regards, Alex. Please rate useful posts.
1 REPLY
Green
Confused on Cube
Alex
251
