Confused re configuring 7912 via cme 3.3, ios 12.4 and files needed
John Cheetley
Level 3
Level 3
To the VOIP and IP telephony techs out there.
I am totally confused for the initial setup/configuration of 7912 phone to CME 3.3 running IOS 14.2(T)
The CME & IOS Compatability website shows necessary firwware to use for above phone (for which I have)
However. Visiting another site http://www.voip-info.org shows other files related to gkdefault.cnf, gk<mac_address> for the phone specific configuration for the 7912.
And then mentions a needed conversion file, ptag.dat, cfgfmt and others but no cisco site shows this
Am simply trying to set up a 7912 phone using SCCP to the above environ
Your assistance and guidance is very much appreciated.
Thanks in advance again
Jonathan Schulenberg
Visiting another site http://www.voip-info.org shows other files related to gkdefault.cnf, gk for the phone specific configuration for the 7912.
The XML configuration files are generated by IOS when you use the 'load' command within telephony-service. You only need to load the appropriate firmware files and have the tftp-server commands to publish them.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp1070512
Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jonathon,
In reply to your link I say thanks. Have read through guide. Some
parts are for SCCP and some SIP so dissected what I needed and setup.
My 7912 phone still doesnt register in CME 3.3.
Phone goes into loop of Configuring IP VLAN,Configuring CMList and Configuring
I run debug tftp events but output is nothing. ie no output.
Run sh ephone registered.
Returns no ephone in specified type/condition
Run sh ephone summary..
cme_router#sh ephone summary
ephone-1 Mac:0017.9570.8E67 TCP socket:[-1] activeLine:0 UNREGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0
IP:0.0.0.0 Unknown 0  keepalive 0
Max 2, Registered 0, Unregistered 1, Deceased 0, Sockets 0
ephone_send_packet process switched 0
Max Conferences 4 with 0 active (4 allowed)
Skinny Music On Hold Status
Active MOH clients 0 (max 76), Media Clients 0
No MOH file loaded
I run debug ephone register..gives no output.
Obviously I am doing something wrong..thanks again
Hi Jonathon,
No MOH file loaded
