Connect CUCM to H323 gateway through CCME
Good day,
Can anybody help me to solve the problem with h323 gateway and CUCM? I have the following ip telephony topology: CUCM 6.1 -> CUCME 7.1 -> Provider's H323 Gateway -> PSTN. When I am calling from CUCME to PSTN it's ok. All incoming and outcoming calls are working. Also all calls from CUCM to CUCME are ok too. But when I am trying to call from CUCM to PSTN it does not work. After dialing mobile number I hear the silence in the handset, but the mobile phone is ringing. When I pick up the mobile phone after few seconds the call disconnects. It seems that signaling doesn't work. But incoming calls to CUCM from PSTN are working normaly.
In the CUCM I add CUCME like gateway with ip address 10.50.2.8 and no MTP.
This is config of CUCME:
voice call convert-discpi-to-prog
voice service pots
fax rate disable
voice service voip
redirect ip2ip
fax protocol pass-through g711ulaw
fax-relay ans-disable
h323
  emptycapability
  h225 display-ie ccm-compatible
  h225 id-passthru
  h245 passthru tcsnonstd-passthru
modem passthrough nse codec g711ulaw
voice translation-rule 9
rule 1 /^[0-9]...$/ /74957758705/ type any national
voice translation-rule 10
rule 1 /^90/ /2660044#0/
rule 2 /^91/ /2660044#1/
rule 3 /^92/ /2660044#2/
rule 4 /^93/ /2660044#3/
rule 5 /^94/ /2660044#4/
rule 6 /^95/ /2660044#5/
rule 7 /^96/ /2660044#6/
rule 8 /^97/ /2660044#7/
rule 9 /^98/ /2660044#7/
rule 10 /^99/ /2660044#9/
interface Loopback0
ip address 10.50.2.8 255.255.255.0
no ip redirects
no ip proxy-arp
ip flow ingress
ip pim sparse-dense-mode
ip virtual-reassembly
interface GigabitEthernet0/0.22
description Voice$FW_INSIDE$
encapsulation dot1Q 22
ip address 172.22.1.1 255.255.248.0
no ip redirects
no ip proxy-arp
interface GigabitEthernet0/0.39
description $H323$
encapsulation dot1Q 39
ip address 10.50.88.2 255.255.255.252
ip access-group 104 in
no ip redirects
no ip proxy-arp
ip accounting output-packets
ip inspect Voice out
no cdp enable
ip route 195.239.254.161 255.255.255.255 10.50.88.1
dial-peer voice 2400 voip
corlist incoming 1
corlist outgoing call-local
description CCM
answer-address 24..$
destination-pattern 24..$
session target ipv4:172.22.1.2
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
ip qos dscp cs5 media
dial-peer voice 98964 voip
corlist incoming call-local
corlist outgoing call-mobil
description h323_beeline
translation-profile outgoing nat_beeline
destination-pattern 989645000441$
session target ipv4:195.239.254.161
incoming called-number 7T
codec g711ulaw
num-exp 74957758705 2407
telephony-service
video
  maximum bit-rate 480
em keep-history
em logout 22:0 23:0
max-ephones 240
max-dn 700
ip source-address 10.50.2.8 port 2000
service phone videoCapability 1
timeouts interdigit 8
timeouts transfer-recall 20
system message Bosco Di Ciliegi
url information http://192.168.2.32/default.aspx
url services http://192.168.2.32/default.aspx
url authentication http://172.22.1.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
user-locale 3 U3 load CME-locale-ru_RU-Russian-7.0.1.1.tar
load 7914 S00105000300
load 7906 SCCP11.8-4-2S.loads
load 7911 SCCP11.8-4-2S
load 7920 cmterm_7920.4.0-03-02
load 7921 CP7921G-1.1.1
load 7931 SCCP31.8-3-3S
load 7960-7940 P00308000500
load 7941 SCCP41.8-4-2S
load 7941GE SCCP41.8-4-2S
load 7942 SCCP42.8-3-3S
load 7945 SCCP45.8-3-3S
load 7961 SCCP41.8-3-3S
load 7962 SCCP42.8-3-3S
load 7965 SCCP45.8-3-3S
load 7970 SCCP70.8-3-3S
load 7971 SCCP70.8-3-3S
load 7975 SCCP75.8-3-3S
time-zone 32
time-format 24
date-format dd-mm-yy
keepalive 360 auxiliary 360
max-conferences 12 gain -6
2 ACCEPTED SOLUTIONS
Re: Connect CUCM to H323 gateway through CCME
Sounds like there is a codec mismatch occurring if the call drops when the called party goes offhook. Can you collect the following debug output for a failed call.
debug voip ccapi inout
debug h225 asn1
debug h245 asn1
Note the calling and called party numbers.
-Felipe
Most likely u were simply missing following command
but since the issue is resolved perhaps u want to mark
this thread as answered.
interface Loopback0
  h323-gatway voip bind srcaddr 10.50.2.8  <---------
debug h225 asn1
debug h245 asn1
-Felipe
Hi, Felipe. Thanks for reply.
This is debug, I called from 2407 to 989645000441:
CRV3845#sh debugging
H.225:
  H.225 ASN1 Messages debugging is on
H.245:
  H.245 ASN1 Messages debugging is on
CCAPI:
  debug voip ccapi inout is ON (filter is OFF)
CRV3845#
CRV3845#
184773: Oct 12 19:12:40.595 GMT: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A000501401F0049005000200043006F006D006D0075006E0069006300610074006F00720000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010580CBC9783337740080A94A26E87A41CB66056101C0A8079600D50D80000700AC16010206B8110080A94A26E87A41CB66056101C0A80796010001000100010010A001000F0140B5000012088144000400010300
184774: Oct 12 19:12:41.567 GMT: //-1/FE080AF4A6FB/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
184776: Oct 12 19:12:44.623 GMT: //39005/FE080AF4A6FB/CCAPI/cc_api_call_info:
   Info Digits=7, Info Complete=FALSE,
   Interface=0x71386A44, Data Bitmask=0x0, Call Id=39005
184777: Oct 12 19:12:45.707 GMT: //39005/FE080AF4A6FB/CCAPI/cc_api_call_info:
   Info Digits=2, Info Complete=FALSE,
184778: Oct 12 19:12:46.755 GMT: H225.0 INCOMING ENCODE BUFFER::= 23C0060008914A00042800B500001240013C05010000C3EFFEA19BDB1B0C00110080A94A26E87A41CB66056101C0A807960180018010A801003A0140B50000123360010100011E2C1E0284881C269E8100036774640000001B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A224204677464011B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
184779: Oct 12 19:12:48.235 GMT: //39005/FE080AF4A6FB/CCAPI/cc_api_call_info:
   Info Digits=6, Info Complete=FALSE,
184781: Oct 12 19:12:49.903 GMT: //39005/FE080AF4A6FB/CCAPI/cc_api_call_info:
184782: Oct 12 19:12:50.895 GMT: //39005/FE080AF4A6FB/CCAPI/cc_api_call_info:
   Info Digits=1, Info Complete=FALSE,
184783: Oct 12 19:12:52.455 GMT: //39005/FE080AF4A6FB/CCAPI/cc_api_call_info:
184784: Oct 12 19:12:52.535 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
184785: Oct 12 19:12:52.535 GMT: :Inside cc_build_feature_vsa
184788: Oct 12 19:12:56.619 GMT: //39005/FE080AF4A6FB/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x71386A44, Call Id=39005
CRV3845#
Also I mentioned that the call is connected with G729 codec, but my provider is waiting G711 codec. Why is it happened?
GENERIC:
SetupTime=418208020 ms
Index=37620
PeerAddress=2407
PeerSubAddress=
PeerId=2400
PeerIfIndex=130
LogicalIfIndex=0
DisconnectCause=2F
DisconnectText=no resource (47)
ConnectTime=0 ms
DisconnectTime=418224220 ms
CallDuration=00:00:00 sec
CallOrigin=2
ReleaseSource=2
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0x80A94A26 0xE87A41CB 0x66056101 0xC0A80796]
IncomingConnectionId[0x80A94A26 0xE87A41CB 0x66056101 0xC0A80796]
CallID=39003
RemoteIPAddress=172.22.1.2
RemoteUDPPort=0
RemoteSignallingIPAddress=172.22.1.2
RemoteSignallingPort=57260
RemoteMediaIPAddress=0.0.0.0
RemoteMediaPort=0
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=inband-voice
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=TRUE
H245 Tunneling=FALSE
SessionProtocol=cisco
ProtocolCallId=
SessionTarget=
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=0 ms
LoWaterPlayoutDelay=0 ms
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = enabled
CoderTypeRate=g729r8 pre-ietf
CodecBytes=0
cvVoIPCallHistoryIcpif=0
MediaSetting=flow-through
CallerName=IP Communicator
CallerIDBlocked=False
OriginalCallingNumber=2407
OriginalCallingOctet=0x0
OriginalCalledNumber=989645000441
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0xFF
TranslatedCallingNumber=2407
TranslatedCallingOctet=0x0
TranslatedCalledNumber=989645000441
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0xFF
GwReceivedCalledNumber=989645000441
GwReceivedCalledOctet3=0x80
GwReceivedCallingNumber=2407
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x81
MediaInactiveDetected=no
MediaInactiveTimestamp=
MediaControlReceived=
LongDurationCallDetected=no
LongDurationCallTimerStamp=
LongDurationCallDuration=
Username=
MlppServiceDomain=0 (NO_MLPP_DOMAIN)
PrecedenceLevel=0 (PRECEDENCE_LEVEL_NONE)
GENERIC:
Felipe,
I solve my problem. I added new gateway with ip address of sub interface on my CUCME - 10.50.88.2. Through this interface I connect to PSTN. Before I have only one gateway with main ip address of CUCME in CUCM.
Whatever, thanks for your help.
interface Loopback0
691
