Connect TR1034+P2-1B to Cisco
I would like to interconnect a Cisco Router ISDN card with Brooktrout TR1034+P2-1B (BRI). Since I need to give L1 clock from the Cisco side, is this a possible scenario?
Thanks!
met
1 ACCEPTED SOLUTION
Silver
Re: Connect TR1034+P2-1B to Cisco
Hi Met,
I have done this many times with PRI, but never BRI.  It has always worked very well and is easy to set up.  I think if you get the cable right everything else will work very well.
Good luck,
Art
If this helps please rate.
Silver
Yes - see the attached link
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t3/feature/guide/dtpri_ni.html
HTH,
Art
Please rate if this helps.
I'm talking about BRI interface. Have you tried it before?
Thanks!
Silver
Thank you very much my friend.
But you think I will not have problems with source clock from Cisco, right? Good Layer1?
met
Silver
Hi Met,
Good luck,
Art
Thank you, I'll give it a try.
+5 for the kindness!
met
234
