03-09-2007 02:34 PM - edited 03-14-2019 08:24 PM
Can I connect an Avaya PBX to the FXS ports on a VG248, or do I have to use FXO ports for the lines?
03-09-2007 03:44 PM
if you mean the "trunk" ports of the PBX then yes. but try to use digital line if you can, with analog there are always problems and limitations.
Log in to Community
