04-10-2007 01:05 PM - edited 03-14-2019 08:55 PM
I have 2 older PBX's, Avaya and NEC, that I want to connect over an MPLS service. The PBX's will connect to a router via a PRI on either side but I'm not sure which ones to use. I'm considering using 2 2821's but not sure if it will do what I want. Does anyone have a recommendation?
Solved! Go to Solution.
04-10-2007 01:18 PM
Hi Roland,
Yes a 2821 will do this perfectly. But also the 2811, and the 2801 too! However, the latter two will require additional PVDM resources to what comes in the voice bundle (16 and 8 channels respectively)
Hope this helps, please rate all useful posts
04-10-2007 01:18 PM
Hi Roland,
04-10-2007 01:53 PM
Thanks for the confirmation.
04-10-2007 01:58 PM
Thank you for the nice rating and good luck with your project.
