01-28-2009 02:01 PM - edited 03-15-2019 03:50 PM
Hi all,
I tried tonight to get a QSIG link from a spare port on my CMM (CUCM6.1 controlled) to connect to our Aspect switch.
Despite trying various settings at both ends, i never saw the CMM go beyond "Layer 1 DEACTIVATYED" when i issued 'sh isdn status' command.
This would suggest that my CMM port never got a proper layer 1 (basic) connection from the Aspect, thus layer 1 never came up.
Ive used a straight-thru cable (cat6) to connect the CMM to the Aspect card.
Im wondering if this should have been crossed, maybe at the Aspect end??
How are most E1 connections done cable-wise? Should it be crossed in some way?
Any help appreciated. A little stuck at the moment :)
Oh - we use MGCP. I set my end in CUCM to be 'user' because the Aspect was set as 'master'. Tried turing CRC4 on and off, and a few other settings - never saw layer 1 come up tho, so i think ive made a basic error somewhere :o)
01-28-2009 02:23 PM
Yes the connection has to be crossed, and do not use ethernet patches as the pairing is different. Please see:
http://www.cisco.com/en/US/docs/wireless/cards/t1e1vwic/1941cvwic/c1941wic.html
01-29-2009 03:05 AM
Many thanks! Sadly i cant get to the link - Cisco page displays saying it is under maintenance :o(
What ar the exact PIN outs? Are these correct?
E1 Crossover
4 5 3 1 2 6 7 8
1 2 3 4 5 6 7 8
Cheers
02-12-2009 03:35 AM
Just to confirm. E1 crossed at the CMM end, straight at the Aspect end worked fine.
We needed to use QSIG with no CRC4 framing. Also had to reset the card in the Aspect (DTICII card) to get the "Multiple_Frame_Established" connectivity.
11-30-2009 06:13 PM
Hi Andy,
We are trying to connect a cisco gateway to an Aspect, but we cannot make calls between them
We are using this config in cisco side:
isdn switch-type primary-net5
controller E1 0/1/0
pri-group timeslots 1-31
description Corsidian01_30trks_ISDN
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
voice-port 0/1/0:15
no echo-cancel enable
bearer-cap Speech
But we are getting this debug error message:
ASSERTION FAILED : ../VOIP/CCTSP/TSP_CDAPI.C: TSP_CDB_ASSERT_CHECK: 9172
Do u have the same configuration? Any Ideas....
