Connecting Cisco CME to a traditional (Panasonic) PBX
Hello
please, i would like to to connect our Cisco CME 2921 router to be able to call our other building using traditional PBX system (Panasonic), i have FXS card already installed on the CME router, please how do i go about this?
please, i need a guide and how i will configure it to work .
VIP Gold
As per me, you need fxo card
As per me, you need fxo card as well at cme router to achieve both side calling. Actually, FXS generate the dial tone so connectivity should like below..
CME (FXS)------PBX (FXO)   (Call from PBX to CME)
CME (FXO)------PBX (FXS)   (Call from CME to PBX)
May someone else confirm it but I have done this kind of integration between Vega Gateways.
Suresh
Hello, i have both FXO and
i have both FXO and FXS on the CME router, do you have any guide i can follow to make this work?
You can refer to the link
You can refer to the link below:
http://www.ciscopress.com/articles/article.asp?p=664150
517
