Connecting Fax server with Cisco 2801 gateway
I wanna connect XMediusFAX fax server with Cisco 2801 gateway with vic2-2bri. When I send fax from outside fax server receive it (with problems, it's slow). But when I try to send fax from XMediusFAX router match dialpeer, bri goes up and then down. Fax server report that he couldn't establish lind with voip gateway. This is configuration:
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
interface BRI0/3/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
dial-peer voice 100 pots
preference 5
destination-pattern 0T
direct-inward-dial
port 0/3/0
dial-peer voice 200 voip
preference 1
destination-pattern 348800
session target ipv4:10.1.1.224
dtmf-relay h245-signal
codec g711ulaw
fax rate 14400
no vad
no dial-peer outbound status-check pots
What can be a problem?
Hall of Fame Super Gold
Re: Connecting Fax server with Cisco 2801 gateway
hello,
it is actually quite strange that the server can receive fax, because your BRI should be configure network side. Please see:
http://cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a008010ef6c.shtml
note: you can omit the command "line-power", however, it should not make a difference.
I will try explain the situation:
Faxserver (10.1.1.224) --> (FEth) Router --> ISDN BRI --> PSTN
244
