Connecting FXS port to Bogen TAMB2 for paging
I am trying to get an overhead paging system working. I have a FXS port connected to a TAMB2 and then to a 100Watt Avaya amp.
The current Avaya system has a paging port which connects to the amp.
I tested the FXS port first by connecting an analog phone and it is working.
when i make a test page, I do not hear anything on the overhead speakers.
I connected the FXS port to the Bogen, then the Bogen to the RJ11 port on the amp
Any thoughts,
Thanks in advance
Randall
1 REPLY
Two ideas for you.
1. Are you sure you need TAMB? If Avaya amp has RJ-11 connector as opposed RCA or 3.5MM it kind of implies in might take an FXS or FXO port input.
2. Did you set dip switches on TAMB correctly?
http://www.bogen.com/products/pdfs/telephonepagepdfs/TAMB2m.pdf
TAMB also does not need -24V power supply if used on FXS port.
-- please remember to rate and mark answered helpful posts --
2967
