Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Connecting IP Phone in different cluster via H.323 gateway
I have configured R2 as H.323 GW and registered to CUCM.
Created route group,route list and route pattern for 9001 phone in CUCM.
call can not be established between these two phones.
Below is the scenario and find the configuration.
I am new in IP Telephony, Please suggest.
Configuration for R1
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.23 00:02:33 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 1417 bytes
version 12.4
hostname CME-VOICE
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.0.1 255.255.255.252
duplex auto
speed auto
router ospf 10
log-adjacency-changes
network 172.16.0.0 0.0.0.255 area 10
network 192.168.0.0 0.0.0.255 area 10
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
enable password cisco
dial-peer voice 1 voip
destination-pattern 2...
session target ipv4:10.113.113.2
telephony-service
no auto-reg-ephone
max-ephones 10
max-dn 10
ip source-address 192.168.0.254 port 2000
max-conferences 8 gain -6
transfer-system full-consult
ephone-dn  1
number 9001
name LAPTOP-PH
ephone  1
device-security-mode none
mac-address 0025.B347.FD44
button  1:1
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
password cisco
login
end
CME-VOICE#
Configuration for R2
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.23 00:01:49 =~=~=~=~=~=~=~=~=~=~=~=
terminal
CUCM#terminal length 0
CUCM#sh run
Current configuration : 982 bytes
version 12.4
hostname CUCM
ip address 10.113.113.254 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.113.113.254
ip address 172.16.0.2 255.255.255.252
duplex auto
speed auto
router ospf 10
network 10.113.113.0 0.0.0.255 area 10
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
CUCM#
Shibasish
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
You need to add R1 as the GW or ICT in CUCM for direct connection between CME and CUCM, as your dial-peer on R1 points to CUCM via: session target ipv4:10.113.113.2
Chris
Re: Connecting IP Phone in different cluster via H.323 gateway
Describe your call flow, what is R1 doing here? Who is calling who?
Hi chris,
R1 is working as a CME. Currently One Ip phone is registered in R1.Assume that, R1 and R2 are in different cluster. While calling from 9001 to 2001 or vise versa,both way call is not connecting.
Please find the R2's dial-peer with previous config:
R2's dial-peer config
dial-peer voice 2 voip
destination-pattern 9...
session target ipv4:172.16.0.1
Which side is 9001 on and which side is 2001 on?
What is R2 for then?
None of your interfaces on R1 are defined for h323, i.e.
you also need:
voice service voip
Chris
9001 phone is registered in R1(CME) and 2001 is register with CUCM(10.113.113.2). I have already configured R2 as h.323 gw with its interface FastEthernet0/0 interface (already mentioned with earlier post).
shibasish
Chris
That is working. In the previous scenario, I've configured R1 as h.3233Gw in CUCM and it was working fine. Now I'm trying to configure R2 as Gw in CUCM assuming R1 is in at branch office while R2 & CUCM is in at HQ.
Will it be possible?
Shibasish
For what purpose?
You can have both R1 for the CUCM to CME integration, and R2 for whatever other purpose you wan it.
HTH, please rate all useful posts!
Chris
I mean if I leave R1 just as CME (without configring it as h.323 gw), and register R2 as a H.323 Gw then also I am having the same issue.
Shibasish
I dont follow what you are trying to do, your original post was about integrating CME (r1) with CUCM which is done directly without the need for "CUBE" in between, so what is R2 for? What do you have on R2 that you need to integrate to this environment?
Chris
264
