connecting panasonic pbx to cisco ip phone
Hello Dear All,
I have a panasonic pbx, I want to connect my pbx with a FXO device into my callmanager to extend my extention number.
any solution please?
Hall of Fame Super Gold
Re: connecting panasonic pbx to cisco ip phone
hi, you will need a router as voice gateway.
But be aware, FXO ports is not enough, because you won't be able to dial by extension from IP phone to PBX phone. To make the integration work OK, you will ISDN interfaces like BRI.
hi
thank you for your warning but do u know any document for this issue?righ now i have soundwin S400 as fxo gateway.
which documents do you need?
The thing is that PBX phones will never be able to dial directly to IP phones, because the PBX does not outpulse digits on extensions ports. So users will have to dial the number for the gateway first, wait for dialtone, then dial again the IP phone extensions.
All this assuming you can make the third-party gateway to work with CCM.
do you have any documtn on half of you idea?
mine is not an idea, is a fact.
From one extension of your pbx, try calling another extension and possibly add digits after the number.
You will find that these additional digits are not relayed unless the remote extension answer the calls.
This is why interfaces using FXS/FXO are always incomplete and give a bad service to users. At the very minimum, you shoud use both FXS and FXO on BOTH router and PBX, but then it becomes even more complicated and costly.
Integration professionally made are with T1/E1 interfaces, ISDN BRI, ot at very minumum E&M analog trunks
Once you find which interface you can put on the PBX, we can point you to documents with configuration examples.
But you won't find documents for integration using simply an FXO gateway, because it is not the right way to do it.
1011
