Connecting Pansonic tda600 with UC520
Hi ;
I want to connect a UC520 with Pansonic tda600 using  KX-TDA0490 VoIP card.Are these compatible . Any special configuration required on either side  ? Any sample config ?Thanks in advance
Everyone's tags (1)
Hi Aijaz, from what I have
Hi Aijaz,
from what I have seen on the product sheet for the panasonic pbx, it does e1, bri.
(http://hbtcommunications.com/panasonic/kxtda_600.htm). If you have these capabilities on the module that you have bought for the panasonic pbx, then you can use E1 isdn/qsig as the connection between the panasonic side and cisco side.
On the cisco side, you will need to configure an e1 controller. this can be done in various ways.
http://icciev.expertscolumn.com/article/configure-cisco-2821-router-e1-trunk-gateway
http://www.cisco.com/c/en/us/tech/wan/t1-e1-t3-e3/tsd-technology-support-configure-guide.html
here's a discussion that might help.
https://supportforums.cisco.com/discussion/10462196/configuring-e1
Hi, If the Panasonic VoIP card support SIP you can integrante them with a SIP trunk, you should use so much tunning. Regards.
78
