Connecting VoIP and PSTN using E1
I need to connect a voip network with a telephonic switch system using an E1 connection. I was trying to do this using a MC3810, but I noticed that it doesn't support r2-digital signaling and I couldn't make it work using digital E&M too. So, I'm thinking about to buy other router to do this and I need to know if I'm choosing the right router. Does the 2620xm /2621xm support r2-digital in E1? What would I need to connect this, just the router, a Vwic-2mft-e1 and a PVDM2-64? Do I need a NM-HDV2? Would the 2800 series be a better choice in this case?
Thanks for any help,
Fabio
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Connecting VoIP and PSTN using E1
Yes. To use two ports on a vwic-2mft-e1 you need pvdm2-64, to use one you only need pvdm2-32.
You can use a 1861 with a Vwic-1mft-e1 and PVDM2-32 (for 1 E1), and bigger.
I do not recommend you use older routers. However, a 2620xmwith NM-HDV would work.
Can I use a 2801 with a Vwic-2mft-e1 and PVDM2-64? Does 2801 support r2-digital?
121
