Connection KIRK to Callmanager 4.2
hi,
I'm testing the connection betwen CCM 4.2 and a KIRK Server IP1500. We configured the IP1500 Server like the Description from KIRK and also the callmanager. The Problem is, that the phones are connected to the DECT Server are not connected to the CCM.
Any suggestions?
Stephan
1 REPLY
Bronze
Re: Connection KIRK to Callmanager 4.2
Check with region, codec , which protocol used SCCP, any trunk used to connect with the Servers.
Try with the gateway support, mostly it could be a codec mismatch.
177
