Connection PLAR on FXO port
All - I am currently having an issue with a connection plar on one of my FXO ports.
At my Vancouver location, I have a POTs line connected to a FXO port with a connection plar to an IP phone.
When you call the POTs line your hear ringing and the IP phone flashes briefly, but doesnt allow you to pick it up.
Any thoughts?
voice-port 0/3/3
trunk-group Vancouver_FXO
no battery-reversal
cptone CA
timing hookflash-out 50
connection plar 326099
description POTS Line 604-526-XXXX
caller-id enable
Jaime
Re: Connection PLAR on FXO port
Try "connection plar opx 326099" Also if you're not paying for caller-id, I would remove the "caller-id enable" command, this can cause issues.
Yosh
HTH Regards, Yosh
Yosh - that seemed to improve the process.  The IP phone now has full rings, but when you answer, it just disconnects.  The caller still hears ringing.  And the IP phone will start ringing again, but the call can not be answered.
Jaime
Jaime,Have you solved that
Jaime,
Have you solved that issue? I have the exact same situation in a client, the only difference is that it is working fine on one single FXO port, but not on the other 3.
Thank you,
Bruno
Ok how do yuo have configured the GW and what are you using CUCM/CUCMBE/CME?
Yosh
HTH Regards, Yosh
The GW is configured as H.323 and I am using CUCM v. 8.5
Jaime
Can you post your GW config or atleast the VoIP dial-peers.
Yosh
HTH Regards, Yosh
dial-peer voice 100 voip
preference 1
destination-pattern 326...
modem passthrough nse codec g711ulaw
session target dns:CallAgent01
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 101 voip
preference 2
session target dns:CallAgent02
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 102 voip
preference 3
session target dns:CallAgent03
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 1 pots
trunkgroup Vancouver_FXO
description Inbound and Outbound
translation-profile incoming INCOMING-CALL
translation-profile outgoing OUTGOING-CALL
preference 1
destination-pattern 8T
incoming called-number .
dial-peer voice 911 pots
destination-pattern 911
dial-peer voice 8911 pots
destination-pattern 8911
prefix 911
dial-peer voice 999100 pots
description 326008 Paging
preference 1
destination-pattern 326008
port 1/0/0
dial-peer voice 999101 pots
description 326699 Night Chime
preference 1
service stcapp
port 1/0/1
What CODEC are you using?
In CUCM do you have MTP checked?
Do you have "Wait for far end H245 teminal capability set" checked?
Yosh
HTH Regards, Yosh
Codec is G.711U
Yes, MTP is checked and so is "Wait for far end H245 teminal capability set"
Its strange, as soon as I pickup the call on the IP phone, it sounds like its going to connect the call, and then it just drops.
Perhaps a Codec issue?
Jaime
Do you have G711 as the prefered codec, under your Region and Voice-class codec? I would uncheck the "Wait for far end H245 teminal capability set" and if you still have issues verify that you do have an MTP resource available.
Yosh
HTH Regards, Yosh
Yes, G711 is set as the preferred.  The GW does have MTP resources available.
The weird thing is that, the office said it worked just fine about a week ago.
Jaime
Did anything major changes (upgrades, etc) Did you try resetting the GW? Also did you try unchecking the "Wait for far end h245 TCS"
Yosh
HTH Regards, Yosh
Hi Jamie
Can you find the below?.
1- type under the voice-port
input gain 14
battery-invesla
2- catch debug as debug ccapi inout & debug vpm signal and share , please.
thanks
please rate all useful information
Hi Jaime,
If you are getting Half rings,  I just to get back to you TELCO and get the cabling changed.
I am 100% sure its a cabling issue.
Do let me know how that works.
Rate the post accordingly.
Kevin
Yosh - nothing major changed with CUCM or on the GW.  Yes, I tried  resetting the GW and unchecking "wait for far end h245 TCS".  No luck.
Islam - debug attached:
Kevin - thanks for the info.  I had the carrier dispatch a tech.
Jaime
Hi Jamie
befor checking the debugs
1- did you try the cnfiguration which i shared with you .
thanks
Islam - yes I did.  Still having the same issue.
Jaime
Hi Jamie,
Any Luck, about the Tech from the telco on-site?
Kevin
Hi Jamie
I checked the debugs , disconnect is normal call clearing . Can you check the cable which you get it from the teleco?.
Please rate all useful information
Islam - I am still waiting for the telco tech to arrive.  I am also having someone check the cable.  I am not physically onsite.
I should hopefully have an update shortly.
Jaime
455
