Connection PLAR on FXS port 2821
I have an anlog phone that is located by the main gate.  The phone has been extended and terminated into an FXS port on a 2821 router.  I am trying to configure a connect PLAR on he FXS port, so that when the phone goes off-hook it dials an internal VoIP extension.
I am not having any luck.  Any help would be appreciated.  My config is below:
voice-port 1/0/5
timing hookflash-in 50 0
connection plar 220005
description North gate
caller-id enable
dial-peer voice 220005 pots
destination-pattern 220005
port 1/0/5
dial-peer voice 100 voip
preference 1
destination-pattern 220...
modem passthrough nse codec g711ulaw
session target dns:CallAgent01
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
Thanks!!
Jaime
3 ACCEPTED SOLUTIONS
The call won't go to the VoIP DP, if you have a POTs DP that has a better match.
Yosh
HTH Regards, Yosh
Hi Jamie,
Remove "dial-peer voice 220005 pots"
It should work.
Kevin
Yes you shoudl remove the DP, like Kevin said (+5)
Yosh
HTH Regards, Yosh
Yosh
HTH Regards, Yosh
Yosh - do I need to remove dial-peer voice 220005 pots for the PLAR to work correctly?
Jaime
Hi Jamie,
It should work.
Kevin
Yosh
HTH Regards, Yosh
Thanks guys removing the dial-peer worked!
Jaime
122
