Community Member
Connection plar opx issue
Hello friends,
I have a callmanager express 4.1 and it has been working fine until recently. Below is the except of the configuration.
voice-port 0/0/1
connection plar opx 8533
ephone-dn 22
number 4935
ephone-dn 23
number 8533
ephone-dn 24
number 3333
ephone-dn 25
number 3332
ephone 1
device-security-mode none
description Master
after-hour exempt
mac-address ABCD.EFGH.IJKL
type 7971
button 1:22 2:23 2:24
ephone 2
description Boss
after-hour exempt
mac-address XXXX.XXXX.XXXX
type CIPC
button 1:25
When a call comes on the voice-port 0/0/1, I want it to be forwarded to the correct phone+button. This was working fine from but now, it does not go through. If I change the "connection plar opx" to any number say, 4935 or even 3332, it works fine without any problems.
Please help.
Hall of Fame Super Gold
Re: Connection plar opx issue
perhaps some data structure got trashed, try reloading the router. Since you are in there, upgrade to XJ4 that is the lastest with many bug fixes.
Community Member
Is there much difference between the XJ2 and XJ4?
I am currently running the XJ2.
Thanks.
Yes there is. Like 50 voice-specific bugs fixed. And some are quite ugly ones. Check the release notes.
1030
