Community Member
Connection to H323 service provider
I need to connect CCM to h323 service provider. I have 2811 (c2800nm-ipvoice-mz.124-13a.bin) which is connected to h323 provider. I need to know what configuration i must do on 2811 and what to do on CCM. Thx in advance.
Community Member
Re: Connection to H323 service provider
Try this link for an overview of IP-IP Gateway. It is titled Cisco CallManager to H.323 Service Provider Connectivity.
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_guide_chapter09186a00806b0a0f.html#wp1299753
You will then need to simply add the H323 GW into CCM. Don't forget to Bind your H323 signalling to a specific address. Also replace your default inbound voip dialpeer.
Please rate helpful posts.
Jeff
Hall of Fame Super Gold
only think jgolia hasn't mentioned in his good advice, is that you also need a different image (the IP-to-IP gateway one) on the 2811. These image names ends in _ivs. Cisco requires a license too.
The alternative is to enable direct IP communication between CCM and the h323 service provider.
131
