Connectivity issue with BRI to Nortel PBX
I have a 2811 router with VIC2-BRI-NT/TE and I am connecting this to a Nortel PBX, the cable that I use is a BRI cross over with pins 3 and 4 to 5 and 6. I have set my end as the network and have the following config, I don't have access to the Nortel PBX and only going by what the Nortel tech tells me.
interface BRI0/0/1
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn point-to-point-setup
isdn layer1-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
and when I do the show isdn status I get the following:
ISDN BRI0/0/1 interface
******* Network side configuration *******
dsl 1, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
I have tried different switch types but I am not able to get the layer 1 up. Appreciate your help.
1 ACCEPTED SOLUTION
Right, so to put this one to rest for good I managed to get it working in the end, although a bit different. My configs are posted below; Nortel as the "network" and Cisco the "user"; I could only bring it up using QSIG. Oh, and I'm in Europe (Ireland) so had to use A-law on the BRI and cptone IE (tones and cadences for Ireland).
*************************The wiring********************************
Amphenol (Nortel)             RJ-45 (Cisco)
White-Blue                       Solid Blue
Blue-White                       White-Blue
White-Orange                   Solid Green
Orange-White                   White-Green
*************************CISCO config****************************
interface BRI0/0/0
no ip address
isdn switch-type basic-qsig
isdn static-tei 0
voice-port 0/0/0
compand-type a-law
cptone IE
dial-peer voice 1 pots
description Incoming-Calls
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 2040 pots
description Calls-to-Nortel
destination-pattern 204.
no digit-strip
port 0/0/0
*************************NORTEL - LD 16 Route config****************************
TYPE RDB
CUST 00
DMOD
ROUT 10
DES  BRI
TKTP TIE
NPID_TBL_NUM   0
ESN  NO
RPA  NO
CNVT NO
SAT  NO
RCLS EXT
VTRK NO
NODE
DTRK YES
DGTP BRI
IFC  ESGF
CLID OPT0
SIDE NET
CNEG NO
OVLR NO
OVLS YES
OVLT 0
MBGA NO
PGPN 1
RCAP COLP
ISDN YES
    MODE PRA
    PNI  00000
    NCNA NO
    NCRD NO
    CHTY BCH
    INAC NO
    CPFXS YES
    DAPC NO
    INTC NO
DSEL VOD
PTYP DTT
AUTO NO
DNIS NO
DCDR NO
ICOG IAO
SRCH RRB
TRMB YES
STEP
ACOD 8001
TCPP NO
TARG 01
CLEN 1
BILN NO
OABS
INST
IDC  NO
DCNO 0 *
NDNO 0
DEXT NO
SIGO STD
STYP SDAT
MFC  NO
ICIS YES
OGIS YES
TIMR ICF  512
     OGF  512
     EOD  13952
     DSI  34944
     NRD  10112
     DDL  70
     ODT  4096
     RGV  640
     GTO  896
     GTI  896
     SFB  3
     IENB  5
     TFD  0
     VSS  0
     VGD  6
SST  5 0
DTD  NO
SCDT NO
2 DT NO
NEDC ORG
FEDC ORG
CPDC NO
DLTN NO
HOLD 02 02 40
SEIZ 02 02
SVFL 02 02
DRNG NO
CDR  NO
NATL YES
SSL
CFWR NO
IDOP NO
VRAT NO
MUS  NO
PANS YES
MANO NO
FRL  0 0
FRL  1 1
FRL  2 2
FRL  3 3
FRL  4 4
FRL  5 5
FRL  6 6
FRL  7 7
OHQ  NO
OHQT 00
CBQ  NO
AUTH NO
TTBL 0
ATAN NO
OHTD NO
PLEV 2
OPR  NO
ALRM NO
ART  0
PECL NO
DCTI 0
TIDY 8001 10
SGRP 0
ARDN NO
AACR NO
*************************NORTEL - LD 27 BRI trunks config****************************
>ld 27
REQ  new
TYPE dsl
DSL  2 0
DATE
PAGE
NACT
TN   2 0 0 0
APPL BRIE
  ISDN_MCNT 300
CUST 0
CTYP SILC
MISP 1
MODE NT
TKTP TIE
CLOK NO
PDCA 1
ROUT 10
T302 15
T310 120
B1
  MEMB 1
  TGAR 0
  NCOS 0
  CLS  UNR APN
B2
  MEMB 2
  TGAR 0
  NCOS 0
  CLS  UNR APN
DATE 13 SEP 2013
REQ  end
*************************NORTEL - LD 86 RLB config****************************
REQ  new
CUST 0
FEAT rlb
RLI  10
RLI  10   --------------->>>> this needs to point to the route you configured in LD 16
ENTR 0
LTER NO
ROUT 10
TOD  0 ON  1 ON  2 ON  3 ON
     4 ON  5 ON  6 ON  7 ON
VNS  NO
CNV  NO
EXP  NO
FRL  0
DMI  0
FCI  0
FSNI 0
BNE  NO
SBOC NRR
IDBB DBD
IOHQ NO
OHQ  NO
CBQ  NO
ISET 0
NALT 5
MFRL 0
OVLL 0
*************************NORTEL - LD 87 DSC config****************************
REQ  new
CUST 0
FEAT cdp
TYPE dsc
DSC  10     ------------------------>>>> I have extensions starting with 10xx in the CISCO so this is a wild card
FLEN 4
DSP  LSC
RRPA NO
RLI  10
NPA
NXX
That's what worked for me. None of the other configs I've tried out there did the trick.
Hope this helps anybody who ever gets stuck with something similar.
Cheers guys!
Re: Connectivity issue with BRI to Nortel PBX
- Verify that the interface is not shutdown by executing the show interfaces command.
- Verify that the switchtype is what the Telco specified by issuing the show isdn status command.
- If necessary, configure a different switchtype by issuing the isdn switchtype command.
- Verify that you have the appropriate BRI hardware (for example, U interface in North America and S/T interface in Europe).
- Verify the cabling and pinouts. You should also try swapping out the cables.
Hi there,
I'll be looking at setting up something similar in the coming days. Did you manage to get this working in the end? What was the catch to it?
Thank you
Hi, it was an issue on the Nortel PBX end and was fixed by them. My config was fine.
Hi there hadisharifi,
I really appreciate the feedback. Now i just need to make sure I don't mess up the Nortel side of things (am doing both system ends).
Take care.
Kind regards,
Tudor
Hi hadisharifi,
So I'm facing these 2 systems, tried a lot of combinations but I have the same problem; I can't get the link up no matter what I tried so far (tried even QSIG type on both switches)..
You wouldn't be able to find out what exactly they changed on the Nortel side to bring this freakin' link up would you? I'd be very grateful for any info you'd be able to pass my way; I need to know what in blazez I need to change.
Many thanks.
Tudor
interface BRI0/0/0
no ip address
isdn static-tei 0
voice-port 0/0/0
compand-type a-law
cptone IE
direct-inward-dial
port 0/0/0
no digit-strip
port 0/0/0
TYPE RDB
CUST 00
DMOD
ROUT 10
DES  BRI
TKTP TIE
NPID_TBL_NUM   0
ESN  NO
RPA  NO
CNVT NO
SAT  NO
RCLS EXT
VTRK NO
NODE
DTRK YES
DGTP BRI
IFC  ESGF
CLID OPT0
SIDE NET
CNEG NO
OVLR NO
OVLS YES
OVLT 0
MBGA NO
PGPN 1
RCAP COLP
ISDN YES
    MODE PRA
    PNI  00000
    NCNA NO
    NCRD NO
    CHTY BCH
    INAC NO
    CPFXS YES
    DAPC NO
    INTC NO
DSEL VOD
PTYP DTT
AUTO NO
DNIS NO
DCDR NO
ICOG IAO
SRCH RRB
TRMB YES
STEP
ACOD 8001
TCPP NO
TARG 01
CLEN 1
BILN NO
OABS
INST
IDC  NO
DCNO 0 *
NDNO 0
DEXT NO
SIGO STD
STYP SDAT
MFC  NO
ICIS YES
OGIS YES
TIMR ICF  512
     OGF  512
     EOD  13952
     DSI  34944
     NRD  10112
     DDL  70
     ODT  4096
     RGV  640
     GTO  896
     GTI  896
     SFB  3
     IENB  5
     TFD  0
     VSS  0
     VGD  6
SST  5 0
DTD  NO
SCDT NO
2 DT NO
NEDC ORG
FEDC ORG
CPDC NO
DLTN NO
HOLD 02 02 40
SEIZ 02 02
SVFL 02 02
DRNG NO
CDR  NO
NATL YES
SSL
CFWR NO
IDOP NO
VRAT NO
MUS  NO
PANS YES
MANO NO
FRL  0 0
FRL  1 1
FRL  2 2
FRL  3 3
FRL  4 4
FRL  5 5
FRL  6 6
FRL  7 7
OHQ  NO
OHQT 00
CBQ  NO
AUTH NO
TTBL 0
ATAN NO
OHTD NO
PLEV 2
OPR  NO
ALRM NO
ART  0
PECL NO
DCTI 0
TIDY 8001 10
SGRP 0
ARDN NO
AACR NO
>ld 27
REQ  new
TYPE dsl
DSL  2 0
DATE
PAGE
NACT
TN   2 0 0 0
APPL BRIE
  ISDN_MCNT 300
CUST 0
CTYP SILC
MISP 1
MODE NT
TKTP TIE
CLOK NO
PDCA 1
ROUT 10
T302 15
T310 120
B1
  MEMB 1
  TGAR 0
  NCOS 0
  CLS  UNR APN
B2
  MEMB 2
  TGAR 0
  NCOS 0
  CLS  UNR APN
DATE 13 SEP 2013
REQ  end
REQ  new
CUST 0
FEAT rlb
RLI  10
ENTR 0
LTER NO
ROUT 10
     4 ON  5 ON  6 ON  7 ON
VNS  NO
CNV  NO
EXP  NO
FRL  0
DMI  0
FCI  0
FSNI 0
BNE  NO
SBOC NRR
IDBB DBD
IOHQ NO
OHQ  NO
CBQ  NO
ISET 0
NALT 5
MFRL 0
OVLL 0
REQ  new
CUST 0
FEAT cdp
TYPE dsc
FLEN 4
DSP  LSC
RRPA NO
RLI  10
NPA
NXX
Cheers guys!
I am glad that you have got it working as I wasn't going to be much of help. I left the company along time ago and haven't been working on VOIP since then.
599
