03-16-2012 10:00 AM - edited 03-16-2019 10:10 AM
I all
I've one issue going on with Attendant console 5.1(3) installed in a Windows XP SP3. Just like that the console goes on top of all windows on call arrival or when user places a call. I've reinstalled software and tested in another computer but still having this problem.
Does anyone have an idia how to solve this?
Thank you in advance.
Paulo Magalhaes
Solved! Go to Solution.
03-16-2012 10:07 AM
Hi Paulo,
Have you tried to use this method to enable / disable "Pop to Top" on AC
Note: To toggle the pop-to-top feature on and off, press Alt + P.
Cheers!
Rob
03-16-2012 10:05 AM
There is a setting to change the behavior, forgot what and where it is, but I think i may be in the lower right corner, little button :-)
HTH,
Chris
03-16-2012 10:07 AM
Hi Paulo,
Cheers!
Rob
03-16-2012 10:12 AM
Hi Rob
Did like you said and it's working like a charm.
Thank you very much.
Paulo
03-16-2012 10:30 AM
Hi Paulo,
You are most welcome
Cheers!
Rob
