Console window on top on call
I all
I've one issue going on with Attendant console 5.1(3) installed in a Windows XP SP3. Just like that the console goes on top of all windows on call arrival or when user places a call. I've reinstalled software and tested in another computer but still having this problem.
Does anyone have an idia how to solve this?
Thank you in advance.
Paulo Magalhaes
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Paulo,
Have you tried to use this method to enable / disable "Pop to Top" on AC
Note: To toggle the pop-to-top feature on and off, press Alt + P.
Cheers!
Rob
Hall of Fame Super Silver
There is a setting to change the behavior, forgot what and where it is, but I think i may be in the lower right corner, little button :-)
HTH,
Chris
Hi Paulo,
Cheers!
Rob
Hi Rob
Did like you said and it's working like a charm.
Thank you very much.
Paulo
Hi Paulo,
You are most welcome
Cheers!
Rob
194
