Constant RingBack heard with calls over PSTN SIP are XFERed from UC
mmertens
   I have a CUCM 7.1(3) and Unity Connection 7 deployment with two PSTN connections, 1 SIP and 1 PRI. When calls come in over SIP to an AA, and someone selects an option to XFER to a CUCM Hunt Pilot, the caller on the PSTN hears constant RingBack. The phone(s) in the Hunt Pilot's LG ring normally and all other call processing appears normal. If I call a DID on the PRI which is pointed to the same AA, and XFER to the same Hunt Pilot, Ring back is normal. Normal rining is also heard when I call the AA from the inside and Xfer.
   Also, If I change the UC AutoAttendants XFER to Supervised Transfer, the caller on the PSTN hears one ring back and then silence.
Any ideas? It does seem SIP related.
THANKS!
Joseph Martini
Found exactly like: http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth05703 this only happens with blind transferes not supervised as you've already seen.
Joseph Martini
That was it!!!! Thanks Joe!
