consult missed calls
Is it possible to retrieve a list of missed calls from a phone ? This would display the list on a web page, for example, and to consult this list when I'm not near of my phone.
Gold
Re: consult missed calls
No, there is no such option available. Missed calls are only stored on the phone memory and cannot be accessed from the webpage
Is the missed call can be seen in the CDR database? how to generate missed calls report?
tia
the missed calls should appear as duration 0 calls since they were not connected (you need to enable the parameter for logging calls with zero duration for this). the only issue is that this also will show up calls made from the ip phone.
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
208
