CONTRAST on 7971/7975
tallpaulroe
does anyone know why i am unable to change the contrast on my 7971/7975 phones
all other settings work OK but contrast setting is dimmed and not accessible
8 Replies 8
dsweeny
Level 3
Level 3
go to the CCM admin page > find/select your 7971 > at the "phone configuration page", go to the "Product Specific Configuration" section > look for parameter "Settings Access" and verify that you have it set to "Enabled".
Also is it working on "low-power mode"?
settings access is enabled and i can access all other settings OK such as brightness and colour. it's just contrast that is "greyed"
not sure what you mean bye low power mode ?
i have the display switched off other than when an incomming call switches it on and the display timeout is set for 120 seconds.
have you solved this issue?
We're having the same behavior on 7971/7970 with CUCM 7.0.2.
setting access is enabled
still got the problem, what firmware are you using ?
SCCP 8.4-3 and 8.4-4
i'm using SIP 8.4.4
one other point i have some on power cubes and some on POE and they all do it.
so i dont think it's a PSU issue
I agree, I don't think it's a Power Issue
I've tried PoE with Cat4500 and
2821
Also using the Power Cube didn't change anything.
I've tested this Issue with Firmware 8.5.2 and 8.3.4, however still no solution...
