Convert a wav file to .au
pblumenthal
Hello
I know that the Gateway's support wav files for MoH, but i think the quality is not very well. On the other hand, the default MoH file ( music-on-hold.au ) is excellent.
My question now is, how to convert a wav file from the MoH CD into the au file format?
Maybe there is another better way, i don't know.
Thank you for your help and suggestions.
Pascal
mchandak
Level 7
Level 7
If you are using the Audio Files from the MoH CD, you should be able to rename it to .au and use it. The file format would be the same. Also, AFAIK, you should be able to configure the MoH Audio file name as filename.wav and use it.
mchandak
Level 7
Level 7
Hello
In fact, it seems to be a better quality.
Thank you.
I wish you a nice day.
Pascal
