Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Convert a wav file to .au
Hello
I know that the Gateway's support wav files for MoH, but i think the quality is not very well. On the other hand, the default MoH file ( music-on-hold.au ) is excellent.
My question now is, how to convert a wav file from the MoH CD into the au file format?
Maybe there is another better way, i don't know.
Thank you for your help and suggestions.
Pascal
1 ACCEPTED SOLUTION
Gold
Re: Convert a wav file to .au
If you are using the Audio Files from the MoH CD, you should be able to rename it to .au and use it. The file format would be the same. Also, AFAIK, you should be able to configure the MoH Audio file name as filename.wav and use it.
Gold
Hello
In fact, it seems to be a better quality.
Thank you.
I wish you a nice day.
Pascal
1469
