03-03-2014 12:29 AM - edited 03-16-2019 09:59 PM
I am going to migrate from cm7.1 to 9.1 and I have doubt about the DLU
The Total DLU is 60,810
17,615 DLU used
43,195 DLU unused
Cisco send me the immigration RFP
- Migration to UC Manager Enhanced = 4,800
- Migration to UC Manager 9.x Enh Plus = 2,500
How they calculate it?
What I am known the 6 DLU= 1 Enh license
I have total 60,810 / 6 = 10,135 Enh licenses this what I should have correct me if i am wrong.
For Enh Plus = ?? DLU
Solved! Go to Solution.
03-03-2014 01:11 AM
Hi Ahmed,
You can use User Count Tool (UCT) for calculating DLU to UCL or CUWL.
you can get UCT from the Software Center by downloding using your cco id.
https://communities.cisco.com/thread/25291
Rgds
Novri
03-03-2014 02:19 AM
Hi Ahmed,
You just run the LCU tool 9.1(2) as suggetsed by Novri.Send this output along with file generated from ELM to licensing team to provide u the licenses as per Enhanced/Enhanced Plus/Basic.Earlier you had the option of Compliance check in LCU.
You would get 60 days grace period after u do the migration from 7 to 9 to upload the new licenses on ELM provided by licensing team.
regds,
aman
03-03-2014 01:11 AM
Hi Ahmed,
Rgds
Novri
03-03-2014 02:19 AM
Hi Ahmed,
regds,
aman
