Convert MGCP Gateway to H.323
I am using Cisco 2811 routers as voicegateways with FXO ports to the local PSTN for my remote sites with CallManager 4.3(1). Now, in order to be able to get the CallerID in, I must change my remote voice gateways to from MGCP to H.323.
Does anyone have a good example of the gateway H.323 configuration including the SRST configuration needed?
I have been researching and find bits and pieces but would like to get an example of it all in one place. Then I can do the work in my test environment to verify and refine.
Thanks.
Silver
Re: Convert MGCP Gateway to H.323
here is a collection of pieces for H323 on CCM and FXO sides:
CCM side:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_access/vg_200/config/h323.htm#xtocid293401
H.323 Dial Plan:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_access/vg_200/config/h323.htm#xtocid293402
FXO Configuration:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_access/vg_200/config/h323.htm#xtocid2934017
now the dial plan is ready even for SRST, u just want to add some commands to activate srst, i would recommend u to walk with the comprehensive guide: SRST Admin Guide, but basically here are the srst commands u need:
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_configuration_guide_chapter09186a008086d1e1.html
hth
please remember to rate helpful posts
/majdi
gkeel,
Which model number FXO do you have? I have VIC-FXO, which does not support caller ID. VIC2-FXO does. Verify before moving to H.323.
-Shikamaru
this is a real basic H323 config with SRST
Current configuration:
version 12.1
voice class h323 1
h225 timeout tcp establish 3
!--- Set the timeout to three seconds.
dial-peer voice 100 voip
preference 1
!--- Make this the first choice dial peer.
ip precedence 5
destination-pattern 1...
voice-class h323 1
!--- Apply the voice class to the dial peer.
session target ipv4:10.10.10.2
!--- This is the address of the primary Cisco CallManager.
dtmf-relay h245-alpha
dial-peer voice 101 voip
preference 2
!--- This is the second choice.
ip precedence 5
session target ipv4:10.10.10.3
!--- This is the address of the secondary Cisco CallManager.
end
call-manager-fallback
!--- Enables SRST support and enters Cisco CallManager fallback mode.
max-conferences 8
ip source-address 192.168.1.12 port 2000
!--- 192.168.1.12 is the IP address of the Cisco IOS gateway through which it
!--- communicates with the Cisco IP Phones.
!--- Here, the Cisco IOS gateway is also configured as a Cisco CallManager fallback server.
max-ephones 10
max-dn 10
1667
