10-08-2010 07:44 AM - edited 03-16-2019 01:14 AM
I know it's been asked before, but I can't seem to get my phone to convert.
https://supportforums.cisco.com/message/1176500#1176500
https://supportforums.cisco.com/message/1081618#1081618
https://supportforums.cisco.com/message/1171163#1171163
Can anyone help?
Below is the list of files i have on my TFTP server. Phone is getting an IP from my DHCP and gets TFTP server's IP as an option.
I can see the phone (7960) go out and download files from TFTP, but eventually the phone would show TFTP time out.
OS79XX.TXT (has one line inside P003-08-11-00)
P0S3-08-11-00.loads
P0S3-08-11-00.sb2
P003-08-11-00.bin
P003-08-11-00.sbn
Do I need any other files?
Solved! Go to Solution.
10-18-2010 02:59 PM
Can u try this?
Using wordpad, create a file called SIPDefault.cnf with following contents.
Make sure you have correct .loads file on TFTP (here I am pointing it to
P0S3-08-11-00.loads. Put this file on your TFTP server.
# SIP Default Generic Configuration File
# Image Version
image_version: P0S3-08-11-00
Note: Make sure there is no CRLF or blank space after the filename
and there is exactly 1 space between the : and P (as shown above)
If it still fails, please upload tftp logs along with this file.
10-08-2010 09:13 AM
Most likely, you need to update to an intermediate version before.
10-08-2010 11:40 AM
Log files for CTLSEP000628954235 & CTLSEP000628956511 attached
10-08-2010 11:41 AM
10-09-2010 04:42 AM
With CME or CM, you should use SCCP, not SIP.
10-09-2010 05:20 AM
I need to convert them to SIP so they can be used with asterisk. Phones came from a CME environment, which I no longer have access to.
10-09-2010 08:49 AM
Which SCCP version do they have now ?
Try the corresponding SIP version.
10-09-2010 11:10 AM
it has 8.0 (8.0)
boot load id PC03A300
DSP 4.0(4.0)(A0)
Will try 8.0SIP
10-09-2010 11:28 AM
10-09-2010 12:20 PM
Do a keypad reset sequence.
10-09-2010 12:23 PM
did that # on power up and then 123456789*0#
10-09-2010 12:22 PM
I created XMLDefault.cnf.xml with a tag
now i am getting protocol application invalid on the phone
10-18-2010 01:28 PM
Still looking for help...
10-18-2010 02:03 PM
Saw Document ID: 67942
IP Phone 7940/7960 Fails to Boot - Protocol Application Invalid, but don't think it applies to my phones because they are running 8.0
10-18-2010 02:59 PM
Can u try this?
# Image Version
