Community Member
convert wav G.711 to G.729
How can convert .wav G.711 to G.729 ?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Super Bronze
Re: convert wav G.711 to G.729
Use agcutil.exe; this is what the 'Set WAV Format' utility from Unity uses to switch it's own prompts to g729/g711.
Like so:
D:\CommServer\Utilities\SetWAVFormat>agcutil
Wave conversion utility v1.2
Usage: agcutil [-s src] [-d dest] [[-t targetDB] | [-f targetFormat]]
               [-b buffersize] [-g gainThreshold] [-m minThreshold]
   Target formats:
      g.711/uLaw = 7
      g.711/aLaw = 6
      g.729 = 307
      pcm 16 = 1
D:\CommServer\Utilities\SetWAVFormat>agcutil.exe -s "D:\origwavbackup\Stream Fil
es\aaron.harrison_SubName_000bdaab.wav" -d "d:\test.wav" -f 307
File D:\origwavbackup\Stream Files\aaron.harrison_SubName_000bdaab.wav converted
to g729a
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
There are different ways to achieve this. One of the "easier" ways is to run it trough the MOH translator in CUCM, then you will have four wav files. G711ulaw, G711alaw, G729 and WB.
Roger Kallberg
CCIE # 26199 (Voice)
Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
How do more high volume in .wav G.729 ?
Super Bronze
I don't use the MoH translater for this stuff; as the poster noted it tends to attenuate the volume.
Do you have access to  a Unity server?  (not CUC, or CUE, but good old fashioned Windows-based Unity)?
THere is a CLI utility on the Unity server you can use for this; it is also scriptable if you have lots of prompts.
Aaron
Community Member
I have Unity (Windows). How can convert 711 to 729 without attenuate the volume?
Super Bronze
Like so:
   Target formats:
      g.711/uLaw = 7
      g.711/aLaw = 6
      g.729 = 307
      pcm 16 = 1
to g729a
Aaron
3936
