Converting DLUs from 4.x to 6.x for Soft Phone
Hi Everyone,
During Migration from a 4.x CM environment to a 6.x CCM environment will the DLUs for the Soft Phone(no longer supported on 6.x) be converted during the process. My thoughts are that they should, given the fact that the customer has already paid for those DLUs.
Thanks Guys!
1 REPLY
Re: Converting DLUs from 4.x to 6.x for Soft Phone
my guess is that you should get the DLUs from the CTI port from the softphone during the migration and not for the actual phone (IPC), as you know IPC is one of the devices that takes the most DLUs
this might shed some light on your question
Program Offer for Exchanging Cisco IP Softphone for Cisco IP Communicator
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps5475/prod_bulletin0900aecd80229866.html
java
if this helps, please rate
www.cisco.com/go/pdi
91
