Converting from H323 to MGCP
I am converting from H323 to MGCP. Here is my H323 gateway config:
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
application
global
service alternate Default
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface GigabitEthernet0/0
description Data interface
ip address x.x.x.x 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description Voice interface
ip address y.y.y.y 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr x.x.x.x
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
control-plane
voice-port 0/0/0:23
dial-peer voice 10 pots
description 9911 calling
destination-pattern 9911
port 0/0/0:23
forward-digits 3
dial-peer voice 11 pots
description 911 calling
destination-pattern 911
port 0/0/0:23
forward-digits all
dial-peer voice 12 pots
description Local calling
destination-pattern 9[2-9]..[2-9]......
port 0/0/0:23
forward-digits 10
dial-peer voice 13 pots
description Naional CND/US calling
destination-pattern 9[0-1][2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
dial-peer voice 14 pots
description Service calls
destination-pattern 9[2-8]11
port 0/0/0:23
forward-digits 3
dial-peer voice 15 pots
description International calling
destination-pattern 9011T
port 0/0/0:23
prefix 011
dial-peer voice 16 pots
description Operator
destination-pattern 90.T
port 0/0/0:23
forward-digits 0
prefix 0
dial-peer voice 990 voip
destination-pattern .
session target ipv4:x.x.x.x
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 999 pots
incoming called-number .T
direct-inward-dial
port 0/0/0:23
telephony-service
srst mode auto-provision none
max-ephones 20
max-dn 40
ip source-address x.x.x.x port 2000
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
MGCP Config:
application
global
service alternate default
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager
no cdp enable
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
mgcp profile default
service mgcpapp
destination-pattern 9T
direct-inward-dial
call-manager-fallback
timeouts ringing 30
max-ephones 36
max-dn 72 dual-line
access-code pri 9 direct-inward-dial
I am looking for expert opinion about the config conversion that will work. Appreciate your help.
Thanks.
Hall of Fame Super Gold
Re: Converting from H323 to MGCP
Why do you want to do that? You loose features and flexibility.
That is my customer requirement.
What is better MGCP or H.323 ???
Is your customer properly informed ?
I hear that sentence used too often as an excuse for poor choices.
The customer took the descision and there is no point raising question right now. I wanted to check my configuration before I implement on the system.
158
